The driver's side A/C blows warm air?
149,129 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PETER1974
  • 13 POSTS
The driver on the left blows warm air from the air outlet, and the passenger on the right blows cold air. It takes about 15 minutes to get cold.
Jul 30, 2022 at 6:12 PM
  • 55,711 POSTS
It sounds like you have two problems, first the system sounds like it is low on charge which this guide and video can help you:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Next the left or drivers side blend door actuator is not working which is common. Here is the location and how to change it out in the diagrams below. Check out the diagrams (below). Please let us know what happens.
Jul 31, 2022 at 6:16 AM
PETER1974
  • 13 POSTS
This chart doesn't look like my model, I can't read it and can't locate it. I observed that my car has three blend door actuators, I don't know which one is faulty.
Aug 11, 2022 at 6:34 PM
  • 55,711 POSTS
I put a red arrow on the location of the blend door actuator you need to change out. It is on the driver's side above the throttle pedal.
Aug 12, 2022 at 4:12 AM
PETER1974
  • 13 POSTS
I got a new one today and it works fine. thank you very much.
Aug 25, 2022 at 1:07 AM
  • 55,711 POSTS
Thanks for the image, nice work, we are here to help, please use 2CarPros anytime.
Aug 25, 2022 at 10:16 AM
