The passenger vents is blowing cooler ac air than the driver side. What blend actuator controls that? Where is it located?
Aug 21, 2016 at 10:19 AM
SATURNTECH9
✓Experienced Mechanic
Do you have dual air conditioner temperature control for each side? Also is it manual or automatic climate control?
Aug 21, 2016 at 10:59 AM
CECTECH1
MEMBER
No it does not have a control that allows you to adjust passenger and driver side. Possibly controlled automatically. But i found no information to support that.
Aug 21, 2016 at 3:44 PM
SATURNTECH9
If you do not have a separate temperature control for each side and only have one temperature control? Then you only have one blend door and only one blend door actuator.
Aug 21, 2016 at 3:47 PM
JIS001
Usually when you are low on freon you get the condition you are describing. Have the system checked for leaks.
Aug 22, 2016 at 6:37 AM
SATURNTECH9
I was getting there just trying to make sure there was only one temp control.Yes if the system is low this can happen one side cold and one side cool.Thanks for your input.
