A/C not blowing out of any of the vents
163,000 MILES • AUTOMATIC
RONNIE SONDAY
The AC wont blow any air out of vents .....
Mar 19, 2021 at 11:19 AM
  • 110,246 POSTS
What you described sounds like an issue with the mode door actuator. The mode door is what directs airflow to different places. If you are getting airflow from a different location such as the defroster or floor but can't get it from the dash vents, this is my first suspect.
What I would recommend is to remove the actuator and confirm it is working or actuating when you select a different airflow direction.
If you look at the pics below, they are the directions and pics which correlate with the replacement of the actuator. Use these directions to remove and inspect. If it is bad, replace it.
I hope this helps. Let me know if you have other questions.
See pics/directions below.
Mar 19, 2021 at 1:28 PM
RONNIE SONDAY
When i turn on the AC or defroster there is no air at all that comes out from anywhere is what i'm saying.
Mar 19, 2021 at 10:37 PM
  • 110,246 POSTS
Does the blower motor turn on?
Mar 20, 2021 at 2:22 PM
RONNIE SONDAY
I believe so. someone mentioned maybe it's the fan that's not blowing? Is there a way to trouble shoot that or is a replacement needed?
Mar 21, 2021 at 2:24 AM
  • 110,246 POSTS
If you can't hear the fan turning on, that is the problem. You should be able to hear it.
Take a look at the pics below for trouble shooting an inoperative blower motor. The pics are included as well.
Let me know if this is something you feel comfortable doing.
Mar 21, 2021 at 11:08 AM
