A/C not blowing cold air?
195,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ARLEDGE88
My A/C would blow cold, gradually got worse by not blowing cold air unless vehicle was moving, now it doesn't blow cold air at all
May 10, 2023 at 2:39 PM
  • 110,248 POSTS
This could be the result of low Freon. By chance, do you hear the AC compressor turn on when the AC is requested on? If not, try charging it first.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Also, take a look at this link, you may find it helpful:
Let me know if that helps or if you have other questions.
May 10, 2023 at 2:48 PM
ARLEDGE88
I appreciate it, yes, the compressor comes on and stays on, recharged Freon too.
May 10, 2023 at 2:50 PM
  • 55,721 POSTS
It sounds like you have a compressor that has gone out, so we need to get a set of gauges to check the high and low side.
here is a video to help please let us know what the high and low side pressure are at idle:
https://youtu.be/4EqdrBVb0sY
Please go over this guide and get back to us.
May 11, 2023 at 10:25 AM
