keep the ac blowing out the center of the dash?
100,000 MILES • 4.6L • V6 • 2WD • AUTOMATIC
FROGGY58
What color hose do I disconnect from the actuator to keep the ac blowing out the center of the dash Thank you very much
Jul 11, 2025 at 12:43 PM
  • 55,721 POSTS
The color is the yellow with a green stripe, this line closes the center vent flap when vacuum is applied (diverts air to defrost/floor). By disconnecting it and plugging the line, the center flap stays open, allowing cold air to continue blowing through the dash vents. Let us know if you need anything else.
Jul 12, 2025 at 3:51 AM
