keep getting very low refrigerant reading on dash panel. Freon is not low.
Jan 25, 2017 at 9:20 PM
HMAC300
✓Experienced Mechanic
if you are putting a temperature gauge there then you are reading the air temperature not the Freon level. you need gauges hooked up to system to read that. if your readings are in the forty some degree area on the air temperature then nothing is wrong.
