Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Climate Control
Air Conditioner
Recharge
Discharge and refill the A/C
2007 TOYOTA COROLLA
190,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LASTMOH
MEMBER
I want to discharge and refill the A/C. how much oil i need to add and what type.of course i will recover the old Freon?
Thank you
Aug 10, 2020 at 3:47 AM
Experienced Mechanic
Good afternoon,
If you are not replacing anything, then just add one ounce of Pag 90.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Why are you doing this procedure?
Aug 10, 2020 at 4:50 AM
LASTMOH
MEMBER
the A/C is not cooling well.on the tag it says ND 8 oil. i looked online it says equivalent is Pag 46. is it right?
Aug 10, 2020 at 8:08 AM
Pag 46 is okay to use. 46 and 49 are almost the same and mixing them is not an issue.
Aug 10, 2020 at 8:23 AM
LASTMOH
MEMBER
I looked at the oil they have oils with ICE is it okay to use them?
Aug 10, 2020 at 9:17 AM
No, just get the Pag oil. No additives needed. The Pag has all the additives it needs.
Aug 10, 2020 at 9:08 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
