A/C will not stay on?
120,000 MILES
SANTOSHERNANDEZ
The A/C won't stay on it turns off by itself.
Jul 3, 2024 at 10:32 AM
  • 55,711 POSTS
Does the system have a full charge? If not, the system will turn off and then on again, please go over this video to help see if the charge is good:
https://youtu.be/uZrQCGwXfek?si=hfK2tV1gm8NC8sUu
If the system has a full charge, I would use a test light to see if the compressor is getting power when it is not working which will tell you the compressor clutch is going bad.
Please go over these guides and get back to us.
Jul 4, 2024 at 3:56 AM
