A/C compressor not working
151,689 MILES
TMTAD5
Try to charge but compressor won’t come on.
Jul 16, 2019 at 6:30 AM
Good afternoon,
Why did you change the compressor?
Did you change the dryer and evacuate the system?
How much Freon did you add?
I need as much information as possible.
Jul 16, 2019 at 7:23 AM
TMTAD5
I didn’t much Freon because the compressor didn’t come on to pull it through the system. no, I didn’t evacuates the system. I looked online and it said if my situation happens I could jump start the compressor.
Jul 16, 2019 at 8:52 AM
Okay, first, the system must be vacuumed down to 29 inches for about 30-45 minutes. Then you can add Freon.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
The internet was wrong, again. There is no need to jump-start as they say. It should come on by itself when you add Freon and the pressure goes above 20 lbs on the low side.
Jul 16, 2019 at 9:47 AM
