A/C not working properly when vehicle is stopped
214,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
EDWARDSWKCK
A/C works good when driving not when stopped.
Jun 25, 2022 at 6:10 AM
  • 110,251 POSTS
Have you checked to make sure the system is fully charged? Also, the evaporator is located in front of the radiator. It actually looks like an additional radiator. Check to make sure it isn't excessively dirty. If it is, spray it off with a garden hose.
Now, if the condenser is clean and unobstructed, then chances are you are low on freon. That is where I would start. Take a look through this link and let me know if you are comfortable performing it:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know if that helps or if you have other questions.
Jun 25, 2022 at 4:10 PM
