AC system does hold pressure?
315,000 MILES • AUTOMATIC • HYBRID
THATONEGUY0326
i replaced the old ac compressor with a new one. The new system does hold pressure after being filled but the magnetic clutch is still not engaging
May 4, 2026 at 1:19 PM
  • 55,797 POSTS
If the system has a leak and the pressure is low the clutch coil on the compressor will not come on, here is a video to help you find the leak, if the system was not leaking before the repair then suspect the compressor hose seals.
https://www.youtube.com/watch?v=yrhWKlQEPWw
You can rent the leak detector for free at the auto part store. Please upload a short video in your response of the problem, so I can see what's going on.
May 5, 2026 at 7:40 AM
