Cold air on passenger side hot on the driver side. Please advise.
Aug 20, 2025 at 5:34 AM
✓Experienced Mechanic
Yep, this is common when the driver side temperature blend door actuator goes out. Here is its location so you can swap it out. Here is how to reset the system after the repairs are done.
Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Aug 20, 2025 at 10:39 AM
PETER THE EATER
MEMBER
Alright thank you. I tried to sinc the actuators but it didn't seem to work. Do you have any idea how much the part costs? Maybe? I suppose I have to remove the plastics under the. Steering wheel. Do you have any advise as to where the fasteners are located. I have the one peice dangling but I don't see where the vent is connected.
Aug 20, 2025 at 11:37 PM
You are welcome, the part seems to cost between $65.00 and $110.00 depending on the brand. Once the blend door goes bad it cannot be recalibrated.
Aug 21, 2025 at 12:19 AM
PETER THE EATER
MEMBER
How can I turn on ignition on my push button ignition?
Aug 21, 2025 at 12:36 AM
With your foot off the brake, press the START/STOP button once, the system will turn on.
Aug 21, 2025 at 12:46 AM
PETER THE EATER
MEMBER
That does not seem to have help??
Aug 21, 2025 at 5:00 AM
Did you switch the blend door actuator out?
Aug 22, 2025 at 1:27 AM
PETER THE EATER
MEMBER
No not yet I had to order it.should arrive tuesday.. is there a way to open that one flap
Aug 23, 2025 at 12:51 AM
PETER THE EATER
MEMBER
Aug 23, 2025 at 1:22 AM
PETER THE EATER
MEMBER
Where will the actuator be located on my 2017 invision
Aug 23, 2025 at 2:38 AM
Yes, you can move the blend door pivot to make sure the blend door inside the HVAC plenum works. The actuator in question location is in the images above.
Aug 23, 2025 at 5:19 AM
PETER THE EATER
MEMBER
Is the one I will be replacing? I understood it to be other passenger side of my vehicle.
Aug 23, 2025 at 7:06 AM
PETER THE EATER
MEMBER
I' apologize for bothering you so much . But I think I may need to telltale when I was trying to sync the climate control the temps did change on the riverside and passengerside. But only the passengetside would blow cold and get hot.
Aug 23, 2025 at 7:34 AM
PETER THE EATER
MEMBER
Do you have any insight to share with me as to how to get all of the plastics out that are helping to hold the glove box in it's hole??
Aug 23, 2025 at 1:35 PM
The blend door on the drivers side in on the left above the gas pedal. Please upload an image of what you are having problems with so I can see.
Aug 24, 2025 at 3:50 AM
PETER THE EATER
MEMBER
If my car isn't blowing cold on the driver's side will the actuator be on the driverside
Aug 24, 2025 at 5:23 AM
(Merged)
PETER THE EATER
MEMBER
Well that's great... i don't need to take the plastics and glove box out if the actuator is on the driver side. I won't have to take anything apart. The actuator is in plain site. I think one of the guides I received said it was on the passenger side. Oh well I will have the part tomorrow and I will be in touch. Thanks
Aug 24, 2025 at 3:24 PM
Sounds good.
Aug 25, 2025 at 2:14 AM
PETER THE EATER
MEMBER
Are you still awake Ken l.? I could use some assistance
Aug 25, 2025 at 11:44 AM
PETER THE EATER
MEMBER
I don't know if you received my text or not. But I would like to know how to get the heater vent out of the way . Idont want tobreakit
Aug 26, 2025 at 12:21 AM
PETER THE EATER
MEMBER
How to move heater vent so I can see actuator
Aug 26, 2025 at 12:24 AM
You wont be able to see it, you must listen for the action inside the HVAC plenum.
Aug 26, 2025 at 2:24 AM
PETER THE EATER
MEMBER
I'm just trying to get to the actuator to replace it.its above the heater vent
Aug 26, 2025 at 2:27 AM
PETER THE EATER
MEMBER
I can see it just can't access it
Aug 26, 2025 at 3:04 AM
PETER THE EATER
MEMBER
Well i guess you are done with me thanks I'll see if someone else can help
Aug 26, 2025 at 6:14 AM
PETER THE EATER
MEMBER
My car has climate control. Driver side hot passenger side coldish. Found the actuator on riverside and it seems ok because I could see the gear moving as I cycled the temp control. Do I need to get the system cleaned and recharged? Please advise.
