Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Engine
Symptoms
Stall While Driving
Engine shuts off when A/C is turned on
2007 FORD EXPEDITION
200,000 MILES • V8 • 2WD • AUTOMATIC
ANTHONY POWELL2
MEMBER
1 POST
When I turn A/C on engine shut off.
Aug 5, 2019 at 12:35 PM
BMDOUBLE
Experienced Mechanic
Replace the A/C clutch assembly. The clutch coil is inducing noise in the electrical system and affecting the crank sensor signal which is a 0-1 volt alternating signal that is very sensitive to noise.
Aug 5, 2019 at 11:55 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
