A/C not blowing cold air
160,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
NGUYEN THAO
Hi, I have replaced the A/C compressors, pressure switch, blend window, temperature sensor, and also the condenser. But still not getting cold air. What should I do next? Thanks
Jun 25, 2019 at 6:12 AM
  • 110,248 POSTS
Welcome to 2CarPros.
What are the high and low side pressures? Also, let me know the outside temp when pressures are checked.
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jun 25, 2019 at 3:46 PM
