Take a look at this attachment and see the 125/30 PSI portion. I suspect this is the issue. When you replaced these parts did you add oil? If not, I would suggest pulling the entire system down and evacuating it then add the proper amount of Freon and oil back in. Then check the pressures again.
Here is a guide on this process:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let us know what you find. Thanks
Images (Click to enlarge)
Jun 15, 2020 at 5:29 AM
