A/C not working properly
200,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
LBOSTON
A/C blows cold until i get to a stop light or slow traffic.
May 24, 2022 at 10:09 AM
This is a common sign that the fan is not working properly, or the system has a weak charge.
Basically, when you are moving the air is moving over the condenser cooling the freon but when you stop it is not moving.
So, let's start with checking the fan operation when you are sitting still and then check the pressure in the system.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Once we know what the pressure is we will have a better idea as to what direction to go. I am attaching a chart below which will help with determining what the possible causes are.
If you are going to recharge the system here is a guide that will help assuming you find a weak charged system.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know what questions you have with this and we can go from there.
Thanks
May 25, 2022 at 4:00 AM
