ac not working
155,000 MILES
BOZENA CAPA
Hi, A/C compressor is not activated when l turn on A/C button. A/C button has three pins and only has power. relay and all fuses are okay.
May 28, 2017 at 5:12 AM
  • 55,859 POSTS
First make sure the system has a good charge which you can do by following this link.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Next here is a wiring diagram (BELOW) and a guide so you can do some testing. As you can see by the diagram there are many fuses that run the system.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 31, 2017 at 6:34 AM
BOZENA CAPA
I found the problem, the connector of temp sensor was disconected...a banal error- Thank you for your time.
May 31, 2017 at 7:13 AM
  • 55,859 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jun 1, 2017 at 4:21 AM
