air conditioner issue
2013 AUDI A4
12,000 MILES
VICTOR ORELLANA
I replaced the air compressor and had it charged professionally but still does not work. there is no power to the air compressor fuses are okay. is there a relay and where is it located or what else can it be?
Aug 22, 2016 at 12:50 AM
  • 31,937 POSTS
There is a low pressure cut off switch and a high pressure cut off switch that protects the system take the car back and get them to check system pressures if there has been a small leak the refrigerant may have leaked out to a point that the switch has cut in.
Aug 22, 2016 at 10:20 AM
