air conditioner not working
12,000 MILES
VICTOR ORELLANA
my air conditioner is not working it has a new air conditioner compressor, but it wont turn on. the fuse is good. is there a relay for the air conditioner and where is located?
Aug 15, 2016 at 12:32 AM
  • 31,937 POSTS
The first thing you need to do is get the system pressures checked, if the refrigerant pressure is to high or to low this can shut down the compressor as a safety precaution, low pressure will normally be a leak which is by far the most common reason for this type of problem.
Aug 15, 2016 at 11:15 PM
