After replacing the A/C system the clutch does not turn on?
150,000 MILES • V6 • 2WD • AUTOMATIC
ROBBINS
  • 8 POSTS
Had to put a new A/C system on the car. The old compressor had metal shavings, so I replaced the compressor expansion valve, pressure switch and lines and condenser. now the clutch won't kick in, can't seem to find issue has new relay also and checked fuses.
May 28, 2023 at 8:07 AM
  • 110,248 POSTS
Have you checked fuse 20 in the under-hood fuse box? If not, confirm there is power to and from it.
Next, at the relay, one of the connector pins (either 30 or 87) should have power at all times. Check that. On the opposite side of the relay, pins 85 and 86, one will only have power with the engine running and the AC requested. Check that.
Let me know what you find. See pic below.
See pic below.
May 29, 2023 at 1:05 PM
ROBBINS
  • 8 POSTS
Yes, it will kick the compressor on if I bypass relay, so I changed the relay and no luck, but I found someone has been in the A/C system before after removing condenser and the condenser looks fine.no clogs new expansion valve. Have not swapped the condensor thermostat yet or control panel.
May 29, 2023 at 9:54 PM
  • 110,248 POSTS
If you are able to jump the secondary side of the relay and the compressor engages, the problem is on the primary side. Are you getting power and a ground reference there?
May 30, 2023 at 2:22 PM
ROBBINS
  • 8 POSTS
Going to check that tonight and control panel.
May 30, 2023 at 9:53 PM
ROBBINS
  • 8 POSTS
Okay, so, A/C system is new but can't get past po533. I think problem in on primary side but don't know what else to check.
Jun 2, 2023 at 8:32 PM
  • 110,248 POSTS
I agree, but the P0533 may be preventing the relay from actuating. I attached the diagnostics below specific to the code. Take a look through them and let me know if you are comfortable performing them.
Jun 3, 2023 at 2:39 PM
ROBBINS
  • 8 POSTS
I found the problem,it was blower motor resistor stopping clutch from engaging.fixed resistor all is fine.thanks for all the help.
Jun 5, 2023 at 5:48 AM
  • 110,248 POSTS
Thanks for the update. I'm glad to know you got it fixed and things are working again.
Regardless, take care, and feel free to come back anytime in the future.
Jun 5, 2023 at 12:42 PM
