Codes 2796 and 2426, air conditioning is blowing cold on driver side cool on passenger side
90,000 MILES
JOE BECH
The rear is same way. I do see a lot of water dripping when air is on. had a new compressor put in last year and worked great. now this it isn't. I ran codes 2796 and 2426.
Apr 5, 2020 at 10:40 AM
Good evening,
Do you have a set of gauges that will read pressures on the system? I need the high and low side readings both with the A/C off and with it running. You may be low in Freon from your description.
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
Apr 5, 2020 at 11:15 AM
