MAP sensor location
130,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
VOLVOS80
Cannot find location of MAP sensor (not MAF).
Sep 2, 2018 at 2:08 AM
AL514
  • 5,692 POSTS
Hello, thanks for using 2CarPros.com. Here is a diagram of the MAP location, hope this helps.
Sep 2, 2018 at 3:17 AM
VOLVOS80
Check engine light always on, five codes for MAP sensor. The only sensor I see that resembles my replacement is down just slightly left of middle of engine in a tight space. I can unplug it but cannot remove it as I am afraid I will break it. It has no screws holding it and neither does my replacement part. Possibly a clip holding it in?
Sep 3, 2018 at 12:04 AM (Merged)
  • 110,248 POSTS
The component is not held in with a bolt. Rather, you need to turn it 1/4 turn to remove it. I have attached two pictures for you to follow for the procedure. Believe it or not, there are no written directions, only the pictures.
VOLVOS80
Thank you for your help.
Sep 3, 2018 at 6:41 AM
  • 110,248 POSTS
Happy to help. Let me know if you have other questions or need additional information.
Sep 3, 2018 at 11:56 AM
