ABS/wheel speed sensor?
66,700 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
AKJOHNSON1027
I have gone through four wheel bearings now. Have replaced all brakes including the brake booster, master cylinder, and module, brake lines, wheel speed sensors, CV axle, calipers, etc. The ABS lights keep coming on claiming the wheel bearing is toast. I have a brand-new bearing and a brand new sensor and even tested the sensor to ensure it’s working.
Apr 11, 2024 at 7:45 AM
CARADIODOC
  • 34,415 POSTS
Diagnostic fault codes never say a part is defective. They only indicate the circuit or system that needs further diagnosis. What are the exact fault code numbers?
What is happening with the wheel bearings? Do they make a buzzing noise? Do they become sloppy? What led you to replace all the other parts? Is there any related history that led up to this problem? What are the exact symptoms, and do any of the new parts make those symptoms go away for a little while?
Apr 11, 2024 at 8:05 AM
  • 55,797 POSTS
What is the code number?
Apr 11, 2024 at 11:12 AM
