ABS warning light turned on
54,000 MILES • 4.2L • 6 CYL • 2WD • MANUAL
JAYE HEMBREE
Replaced ABS module. Brake light warning turned off after module replaced. Main computer not recognizing module. ABS. warning light still on. Did have both brake and and light on, now just ABS. shows all sensors good.
May 30, 2019 at 3:08 AM
  • 110,246 POSTS
Welcome to 2CarPros.
When installing a new ABS module, it must be configured (using vehicle as-built data) and calibrated. You need a scan tool that has calibration functions. What this done? It requires a vehicle communication module and the correct software.
See picture 1.
Mar 13, 2021 at 4:02 AM
