ABS/ traction service lights on
195,000 MILES • 1.0L • 6 CYL • 2WD • AUTOMATIC
UNKNOWME
ABS light comes on and service traction also and the pedal at times vibrate when lights pop up.
Feb 9, 2021 at 11:17 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You will have to use a scanner or code reader that supports ABS and traction control features. You can perform a CAN scan which tests all systems. Here is a tutorial showing how to perform a CAN scan:
Also, here is an ABS tutorial for you to view from or site from YouTube..
https://youtu.be/Pb6nXV-iamI
Get back to us with any code information and we can properly diagnose any ABS or traction control issues. Hope this helps and thanks for using 2CarPros.
Feb 9, 2021 at 3:30 PM
