ABS & traction control light stay on
60,000 MILES
W THIESSEN
Digital readout on dash says "service traction" - is this a dealer issue or an indication of a malfunction - vehicle works fine - no trouble codes - disconnection of battery does not extinguish readout - ther is no switch for traction control on dash as the manual would have you believe
Aug 2, 2013 at 11:36 PM
HMAC300
  • 48,601 POSTS
you need to take it to a repair shop to get the light off as well as serviced. anytime the abs unit sends a code the traction control is shutoff so you need a pro to scan it to see what is wrong.
Aug 3, 2013 at 12:49 AM
