ABS /Traction Control Light
73,000 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
SCHELLER
My dash would display after traveling 50ft ABS/Brake/Traction Control lights. I have a “Fix It” that indicated code 2200 (Anti-Brake Module) which I replaced. now when vehicle is started ABS light and Traction Control only light up instantly (but not brake light). will this clear itself out with driving (reset) or do I need to take to dealership for it to be “Flashed”... and is it safe to drive?
Thank you for your time
Oct 10, 2019 at 5:25 AM
Good afternoon,
Yes, it must be flashed to your car. Any shop can do this procedure for you.
Hopefully, that is the issue. Diagnostics should have been done before pulling the trigger on an expensive part. Codes rarely tell you a part failure just the area of failure.
Oct 10, 2019 at 5:54 AM
