ABS Trac off Airbag light on after battery change
206,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
JSCHIP
purchased 2000 venture van. It was advertised with bad battery. I jumped it, test drove and decided to buy it. I drove it home with the old battery in place. There were no issues. No panel warning lights, no problems with trans. Car ran great. After getting home, I installed a new battery reinstalled fuseblock. When I switched the key on, I had a ABS warning light, Trac Off and Airbag light. These stay on constantly now although the brakes seem fine and the trans will shift hard sometimes, sometimes not. Everything was fine before the battery change. Could I be missing a connection. The battery connector to the fuse block spartks when I remove it and reinstall it. It didn't do that initially either.
Sep 4, 2016 at 12:40 AM
HMAC300
  • 48,601 POSTS
get it scanned for codes there may be an abs problem or maybe the abs unit has gone bad from having proper voltage. brakes will seem ok just tht abs won't work. check all your fuses as you may have a draw on the battery.
Sep 4, 2016 at 12:55 AM
