Slowly did not have any brake pedal bled all 4 brakes manually
Got a little bit of pedal back. Drove a while pedal got soft again.
Replace the brake booster, master cylinder and front calipers. Also, rotors and shoes bench bled the master cylinder first then the brakes with the new calipers bled also.
Still have no brake pedal for stopping going to bleed the back calipers soon
In your brake bleeding YouTube, you recommended a “fancy pants scanner”
Do you think it will rectify my problem with the ABS and traction control pump if you believe that’s my problem?
Sep 15, 2023 at 11:03 AM
