ABS system locked up after new braking system put on
280,000 MILES • 4 CYL • AUTOMATIC
DAHART79
I recently had new brake pads, rotars, lines,calipers, and master cylinder put on my car. I drove it home and it would go over 45 miles an hour. Drove it again and it did the same thing. Took it back to the mechanic and he said the ABS system is locked up due to someone putting in the wrong kind of fluid.
My question is, is that possible after all the new brake system was put on and fluid was out, since lines were replaced, could putting wrong fluid in a long time ago just now cause the ABS system to lock up and the car act like brake pedal is pushed down at all times even when you are trying to drive?
Thank you
DAB
Feb 4, 2016 at 9:07 PM
HMAC300
  • 48,601 POSTS
either the wrong fluid or dirty fluid and system wasn't flushed properly.
Feb 4, 2016 at 11:08 PM
DAHART79
So should that be on me or the mechanic since he replaced all the other brake parts?
Feb 5, 2016 at 12:11 AM
that is on the repair shop that did the repair work.
Feb 5, 2016 at 12:40 AM
