Is it possible to add ABS to this car?
201,043 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
RONALD DEVOLD
  • 134 POSTS
Is it possible to add ABS to the car listed above, base model? It did not come with it.
Sep 20, 2023 at 10:41 AM
  • 55,808 POSTS
Sure, you will need to get a donor car and swap out the components such as the hubs, wiring harness, ABS controller etc. Also the instrument cluster is different as well. Let me know if you have any questions when doing the job.
Sep 21, 2023 at 7:36 AM
