ABS system
2005 FORD EXPLORER
105,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
DONLAD54
Need location of the left front wheel speed sensor?
Feb 13, 2017 at 7:20 AM
JIS001
  • CAR REPAIR CONTRIBUTOR
  • 3,412 POSTS
It will be on the left front wheel bolted on top of the spindle. If you need to replace the sensor then do both front sensors at the same time. The reason said is because of the sensor resistance. Since you will have a new sensor you could get a code for the right side sensor.
Also, do not overlook the reluctor ring on the rotors. Sometimes they will be installed crooked or accidentally knocked out of place when installing the grease seals, especially more true if you just had the front brakes serviced.
Feb 13, 2017 at 8:48 AM
