ABS stay on and four wheel light flashing
2006 MAZDA TRIBUTE
74,598 MILES
CHART023
  • 5 POSTS
A passenger pulled my paking brake at aprox 30-40 mph to see if it would slow down, and since that moment, the abs light came up and the 4x4 started flashing.
There is nothing wrong with the car, it brake as well as it did before, no weird sound. The weird thing is that it light up at only at aprox 40 mph, I use my car for a week in town without going faster than 35, and it never poped up, but when i go faster it comes back.The abs light and 4x4 is there when i go above 40 mph and stay until i stop and start the car again and it go away after a minute and will only come back after i go faster than 40 mph. Before I take it to extract the code, i would like to know if you have an idea of what it could be, a crack tone ring, a bad sensor or someting else?
Thanks
Apr 15, 2013 at 9:37 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave
You are correct that it could be a cracked tone ring or a sensor, however I actually suspect that by pulling the parking brake at that speed there could be metal shavings created by doing that that stuck to the sensor causing an error, however there is no substitute for pulling the code as it will lead you to the actual culprit.
If you could retrieve the code and get back to us we will be glad to help you narrow down the cause. Please keep us up to date on your progress and thank you for using 2CarPros!
Dec 14, 2020 at 8:03 PM
