ABS stabilator and AWD off the lights illuminated?
120,000 MILES • 4 CYL • AUTOMATIC
CALVIN WIDEMAN
  • 19 POSTS
After changing both wheel assembly hubs on both sides the ABS stabilator and all-wheel drive off lights are still on. how do I get them off?
Dec 3, 2022 at 11:09 AM
  • 110,248 POSTS
As I believe you are aware, for all of these to turn on, it is likely you have a bad wheel speed sensor. Have you checked the ones that were not replaced?
If not, I would check to see if there is a signal from them. You can check them with a voltmeter or multimeter.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
On the other hand, if you have a live data scan tool, you can drive the vehicle with it connected and check for speed signals from all sensors. If one is off or not working, that is where the problem is.
Let me know if you are comfortable performing the above test.
Dec 4, 2022 at 10:25 AM
