Abs, stabilitrack, traction control
2013 GMC SIERRA
170,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
MICHAEL LINES
When I am driving my truck and press on the brakes the service stabilitrak, service traction control and service abs lights come on. The truck occasionally disables these functions. When I hit the brakes my head lights dim. I thought maybe ground issue but used sandpaper to clean off ground and frame where it attaches and still same issue. Lights usually go off when brakes are released and i accelerate. Any help is greatly appreciated
Sep 10, 2019 at 9:02 AM
94 TRANSAM
  • 680 POSTS
Hi Michael, welcome to 2CarPros.
Do you have access to a scanner to retrieve the codes? Here is a guide to tell you how to get them.
If not, can you take it to a parts store and have them pull the codes for you?
I need all the code numbers it gives you.
Thanks, Rich.
Sep 10, 2019 at 2:01 PM
