ABS replacement and reprogramming
135,000 MILES • 5.3L • V8
JOHN CAMARILLO
After replacing the ABS module in my SUV. Does this require “reprogramming” the ABS module with the SUV's computer?
Jul 30, 2018 at 9:21 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Yes, you will have to have a GM scan tool hooked up to your vehicle and have a "Tire Size Calibration" performed. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Mar 11, 2021 at 5:25 AM
JOHN CAMARILLO
No, what is Tire Size Calibration got to do with programming an ABS module?
DANNY L
  • 5,648 POSTS
Hello again.
Is your ABS light on?
Danny-
STEVE W.
  • 15,390 POSTS
The ABS module uses the tire size to know what the signal from the wheel speed sensors means. Plus you may need it to bleed the system depending on how you replaced it. If you only replaced the control solenoid block you may not need to bleed it, if you replaced the entire unit and removed the brake lines you will need it to open the solenoid valves to get the air out.
