What are the ABS relay's part numbers?
2008 LEXUS LS 460
140,000 MILES • V8 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Can you find out for me the part numbers for the two ABS relays on this car, one on the right and one on the left side of the car under the hood.
Oct 12, 2022 at 11:07 AM
  • 110,240 POSTS
What I was able to find was part number 8826321010. I attached the parts/labor info below for your review.
As far as the relay, chances are two wouldn't fail at the same time. Here is a link that explains how to test one:
see pic below.
Oct 12, 2022 at 2:26 PM
BHAMDOC1973
  • 2,007 POSTS
I just need to find one. How many ABS relays does the car have and their part numbers? I know both wouldn't fail, am trying to find out if they have the same part number.
Oct 12, 2022 at 10:56 PM
  • 110,240 POSTS
I just went through the wiring again. There only appears to be one ABS main relay. Have you found two or has someone told you there are two? I have been wrong in the past and will be again in the future (LOL), but from what I see, there is only one.
Oct 13, 2022 at 11:43 AM
BHAMDOC1973
  • 2,007 POSTS
Hmm, that is what my friend was told, but online more than one video shows 1 on right side and another on left side in relay boxes, unless its fuses.
Oct 13, 2022 at 11:57 AM
  • 110,240 POSTS
I just found it and you are correct. I didn't realize they had them in two different relay boxes. I had to page in 4 pages in the schematic to find the second one.
Oct 13, 2022 at 12:38 PM
BHAMDOC1973
  • 2,007 POSTS
Can you get the part numbers?
Oct 13, 2022 at 1:09 PM
  • 110,240 POSTS
The part number I attached above is correct. The relay must be the same type because it is the only one listed.
Oct 14, 2022 at 2:12 PM
