I hooked a scanner to my car, and it says the ABS pump has 0 volts. is this normal?
Nov 9, 2021 at 2:35 AM
STARLORD1976
MEMBER
It actually says ABS pump feed a red 0 beside it.
Nov 9, 2021 at 3:11 AM
✓Experienced Mechanic
Do you have the code that was retrieved? There are a few technical service bulletins related to low voltage / no voltage and I'm not sure what direction to go.
Nov 9, 2021 at 11:42 AM
