I have seen this problem before which means the ABS control module is probably bad. Here is a guide that will show you what you are in for when changing the unit out.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Check the fuses just to be safe
There is a fuse panel diagram (Below)
Replacement:
Carry out programming/encoding
Here is how it will be done on your car (below)
Cheers, Ken
Images (Click to enlarge)
Nov 27, 2017 at 6:29 AM
