Abs problem sensor signal?
226,266 MILES • 0.7L • 4 CYL • 2WD • AUTOMATIC
MUCO POLYTECHNIC
Pleasure sensor signal has been detected with scanner tool is there any help I can get apart from replacement of all abs like repairing module or finding other motherboard for abs module
Dec 18, 2025 at 5:58 PM
  • 55,770 POSTS
What code are you getting? Usually when you get a pressure code the pump is bad inside the ABS unit. FYI. I would get a used unit from ebay, I have had good luck with used parts from there. Ken
Dec 19, 2025 at 3:20 AM
