they said I need a new brake master cylinder
130,000 MILES • 0.8L • 4 CYL • 2WD • AUTOMATIC
BRANDY WAGNER
I took my car in to have the ABS factory recall fine and they said it didn't qualify and they said I need a new brake master cylinder
May 25, 2019 at 10:49 AM
  • 110,248 POSTS
Replacing the master cylinder isn't a difficult job. If you take your time, you should have no problem.
To get you started, here is a link that shows in general how it is done. You can use this as a guide.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
If you look at the attachments below, they include the procedures for the removal and replacement of the old one.
I hope this helps. Let me know if you have other questions.
Apr 23, 2021 at 4:56 PM
