The ABS motor will not run. Will the module control that?
Apr 3, 2018 at 2:06 AM
✓Experienced Mechanic
Good afternoon.
How do you know it will not run? how did you test it?
Is the ABS light on? if it is, what is the code?
Apr 3, 2018 at 3:12 AM
JOY PETERSON
MEMBER
Yes, I scanned the ABS box and it said the motor will no't run. Does the module control the motor to run? What is more likely to be shot the motor or the module?
Apr 3, 2018 at 3:43 AM
yes, it does.
what was the code you got??
Apr 3, 2018 at 3:57 AM
JOY PETERSON
MEMBER
sorry I do not remember, I had a friend come in scan it for me. thanks for responding so quickly to my questions though.
Apr 3, 2018 at 4:17 AM
See if you can get the code for me. I need that to help narrow the area of failure.
you need an advanced scan tool to test the motor to see if it works. did your friend have a real scan tool or code reader.
Apr 3, 2018 at 4:44 AM
JOY PETERSON
MEMBER
he had a code reader.
Apr 3, 2018 at 4:47 AM
Okay, get me the code and we can continue from there.
Apr 3, 2018 at 4:49 AM
JOY PETERSON
MEMBER
Okay, the guy is at work right now so I will have to get it later. I will let you know what it is when I get it.
