abs light come on and motor keep spinning even when the vehicle is switch off.
Jun 5, 2016 at 12:06 PM
HMAC300
✓Experienced Mechanic
pull fuse for abs, then have it scanned to see if it is bad, which it probably is. they can be rebuilt. if you pull fuse for abs brakes will still work just no abs.
Jun 6, 2016 at 12:33 AM
MAXIMILIAM
MEMBER
We did pull out the fuse but it was still spinning.
