ABS module replacement and possible reprogramming
74,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RANDYSCOUPE
I am going to replace my ABS module that was diagnosed by my local Ford dealer as bad and it quit communicating. I’m going to replace it with a used ABS module from a vehicle same year same model Mustang as mine. the question is, do I have to reprogram anything after used module is installed?
Mar 25, 2019 at 1:35 PM
Good morning,
Yes, it must be programmed to your VIN before it will function.
Mar 25, 2019 at 10:16 PM
RANDYSCOUPE
Do I have to take it to the Ford dealer for a re-program or can your basic auto repair shop do that? thanks, Randy
Mar 25, 2019 at 10:53 PM
Any shop can do this provided they have the correct scan tool for programming. I would call around to be sure the shop can do it prior to taking to them.
You are welcome.
Always glad to help.
Mar 25, 2019 at 10:56 PM
