ABS module has a humming noise after removing the key?
140,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ICE-COACH
ABS warning light came on. ABS module has a humming noise after removing the key. had to disconnect battery to stop the noise. I'm thinking module needs to be replaced. Pulled fuse, seems to be fine. If a wheel speed sensor was the cause of for the ABS warning to be on, that wouldn't be the reason that the module continues to run/make noise after vehicle is off, would it? Thanks!!
Apr 6, 2021 at 4:32 PM
  • 55,743 POSTS
It is common when the ABS module goes out it continues to run. this video will show you how to replace it:
https://youtu.be/lUotkKXG9dY
Let us know what happens and please upload pictures or videos of the problem.
Apr 13, 2021 at 2:32 AM
