ABS light on and no codes
123,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
MATTHEW ARMSTRONG
ABS light is on, used Autel Autolink al619, it says that it passed, with no codes. Wondering what direction to go next. Fuses are good.
Mar 18, 2017 at 6:50 AM
CARADIODOC
  • 34,415 POSTS
Code readers only read codes in the Engine Computer. You need to find a mechanic with a scanner that can access the Anti-Lock Brake Computer to read the codes in it.
Mar 18, 2017 at 6:52 AM
