ABS light, stable tract light and battery light blinking?
200,000 MILES
SHANTELLE18
Got a flat Turing on a bad part of the road. Changed it and put a dummy on for a day, after going to the tire shop from getting a tire put on the stable tract light, ABS light and battery light came on and car stall and now want start back up.
Aug 4, 2022 at 12:07 AM
  • 110,248 POSTS
The stability track/ABS shouldn't cause a no-start. However, you mentioned the battery light was flashing. When you try to start it now, does the starter engage and turn the engine or do you only hear a clicking sound or a single click?
I have a feeling low voltage is what set the stability track light due to the alternator not charging or the battery has failed internally.
Aug 4, 2022 at 11:05 AM
SHANTELLE18
A hear a single click when trying to start.
Aug 4, 2022 at 11:25 AM
  • 110,248 POSTS
Either the battery is very weak, the starter is bad, or we have a weak connection. Have you checked the battery terminals to make sure they are tight, clean, and free of corrosion? If so, then I need you to perform a simple battery load test. No tools are required.
Follow the directions in this link and let me know the results:
I will watch for your reply. Also, let me know if the click you hear seems to come from the starter.
Aug 4, 2022 at 3:15 PM
