ABS light traction control light and check engine light are on
1999 BUICK REGAL
210,174 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MANDY BRIGHT
It just started over the weekend, the ABS and traction control light started coming on, the lights go off occasionally and stay off. Then they come back on, I can stop just fine, when I got the car was told that they didn't know why the traction control didn't work, car sat up for a little while. I need my car. What could be the problem and how can I fix it without it costing me an arm and a leg? Have had the car for almost three month without this happening, I am worried it's something major.
Oct 20, 2020 at 2:22 PM
Good morning,
There are fault codes stored for both the engine light and the ABS. I need the codes that are stored.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
You can go to a parts store and have them read for free. Once you have the codes, I can help narrow the area of failure for you.
Keep me updated so I can help you further.
Oct 20, 2020 at 10:49 PM
