Rear ABS harness left side have power, but right side no power. Where should I check? the fuse looks good. Do they have relay on ABS system?
Mar 11, 2022 at 9:09 PM
✓Experienced Mechanic
Good morning,
I attached the wiring diagram for you to view. You need to test the wire for voltage coming out of the module to determine if it is a wiring issue or a module issue.
