ABS light stays on
2000 NISSAN XTERRA
125,000 MILES • 5.0L • 6 CYL • 2WD • AUTOMATIC
ZEIK1154
  • 26 POSTS
Causes for ABS light to stay on?
Oct 21, 2019 at 1:59 AM
There are many reasons. Could be a speed sensor to the module itself or just a fluid issue.
We need to get the codes out of the module and that will point us in the right direction.
Here is a video that explains this a little more. Just make sure the code reader can pull codes from the ABS or it will return none.
https://youtu.be/rTtAnsOlZU4
Oct 21, 2019 at 9:14 AM
ZEIK1154
  • 26 POSTS
How do we know if ABS is brakes or airbag? Is it same light that cones on? I am confused..
Oct 22, 2019 at 12:41 AM
Take a picture of the light and I will let you know.
Oct 22, 2019 at 10:44 AM
ZEIK1154
  • 26 POSTS
I don't have a camera phone. light is orange and says ABS stays on.
Oct 23, 2019 at 2:00 AM
Okay. If it says ABS then that is the Anti Lock Brake system. Let's get the codes that it has in the module and we will be able to figure this out. If you don't have a code reader then most parts stores have them and will do it for free. Just make sure their tool can read ABS as well. Thanks
Oct 23, 2019 at 12:10 PM
ZEIK1154
  • 26 POSTS
Okay, will go to part store and see if they can read this. thanks again
Oct 24, 2019 at 12:54 AM
You are welcome. Please let me know what you find and if they try to tell you there are no codes then most likely they cannot read ABS codes because if the light is on there are codes to go with it. Thanks. We will wait to hear back.
Oct 24, 2019 at 7:44 AM
